• Using Subtotal to sum filtered column of numbers but exclude negative values
    Home » Forums » AskWoody support » Productivity software by function » MS Excel and spreadsheet help » Using Subtotal to sum filtered column of numbers but exclude negative values
    I am trying to find out how to sum a column of filtered numbers but not include any negative values in the sum.
    The SUBTOTAL function works on the filtering part but I can’t find a way to limit it to non-negative numbers.
    Any suggestions?
    Thank you for your help.
    Viewing 5 reply threads
    • #1554523
      ryandric,
      Welcome to the Lounge as a new poster! :cheers:
      Are you using SubTotal on more than one column? If not just extend your filtering to filter the SubTotaled column to numbers > 0.
      Setup:
      43767-STBase
      Select Groups A&C:
      43768-STGroupFilter
      Set Number Filter:
      43769-STGTZero
      Results:
      43770-STResults
    • #1554548
      Thank you for your quick reply. I should have been clearer in my explanation.
      I am filtering on columns A and B but Subtotaling column C. Columns A and B are text and column C has numbers in it.
      The Subtotaled column does not have a filter.
    • #1554552
      ryandric,
      So is there a reason you can’t filter Column C for numbers > 0? :cheers:
    • #1554672
      ryandric,
      The following formula will subtotal positive numbers in a filtered list. It assumes you have a header in cell A1 and the data is in the range A2:A99. You can place the formula in A100
      =SUMPRODUCT(–(A2:A99>0),SUBTOTAL(9,OFFSET(A2:A99,ROW(A2:A99)-ROW(A2),0,1)))
      HTH,
      Maud
    • #1554674
      Maud,
      Thank you. This is what I was looking for. I am not able to filter column C because the negative values still need to be visible.
      • #1554757
        Hi ryandric
        I like Maud’s formula method.
        ..another method is to use a custom function:
        Code:
        Function sumVisiblePositive(r As Range)
        For Each cell In r.Cells
        If cell.Height  0 Then
        zValue = cell.Value
        If IsNumeric(zValue) Then
        If zValue > 0 Then
        zTotal = zTotal + zValue
        Next
        sumVisiblePositive = zTotal
        End Function
        You add this code to a standard vba module, and use it in the spreadsheet like any Excel formula, for example
        =sumVisiblePositive(A2:A99)
        zeddy
    • #1554837
      Zeddy,
      This VBA module works perfectly.
      Thank you.
      ryandric
    Reply To: Using Subtotal to sum filtered column of numbers but exclude negative values
