Good day to all.
I rebuilt a friend’s Vista Home Premium laptop last fall: new hard drive and a completely fresh OS install. Machine worked fine until recently.
She sent it to me no longer working. The symptoms are: machine appears to boot normally, but the login page does not appear. Instead, all I see is a black screen with a mouse pointer. Mouse pointer moves normally.
The Caps Lock and Num Lock keys toggle their respective LEDs normally.
Its as if the Windows shell is simply not loading.
What I’ve tried so far:
1) mash the F8 key while booting, select “restore last known good configuration”. No change.
2) mash the F8 key while booting, select “Repair Computer”. The machine boots and I get the normal color screen asking me for the username and password. I enter those and the repair utility does its thing. But: it says that all items are OK. The last item in the log is “Root cause found: Boot status indicates that the OS booted normally.”
I’m not sure what to try next. Unfortunately, the owner did not send to me either the OS install disk or the drivers disk. I can get them sent out but that will take several days. I don’t have any Vista install media here – I made a conscious decision to avoid Vista.
What I’m hoping is that someone can offer suggestions that I can do either with the laptop directly or by pulling the hard drive and connecting the drive to one of my XP or Win7 computers.
Any suggestions greatly appreciated.
dwayne
