Hi,
Is there anyway to auto max db window when user click the database? But the start form will stay as default.
Regards
Home » Forums » AskWoody support » Productivity software by function » MS Access and database help » Auto Max db window (2003)
Do you really mean the Database window? That shouldn’t be visible in a “real” database application, so there is no reason to maximize it.
Or do you mean the Access application window? Access will “remember” the state of the application window, so if the user maximizes it once, it will come up maximized the next time.
With the very large flatscreen monitors available nowadays, it may not be a good idea to force the application window to be maximized – on a widescreen monitor the user may have good reasons to want to display two applications side by side.
Notifications
