• Avast Free UI fails to load constant problem
    • This topic has 0 replies, 1 voice, and was last updated 7 years ago.
    Hi After updating to to Windows build 1803 on 4/29/18, avast free antivirus is constantly giving me the message UI failed to start. I have tried to restart the remote desktop like 5 times already and the problem keeps reoccuring. Thoughtr I would try
    AVG free and had the same problem. I’ve used Avast free for 4 years already and dont want to switch. Right now I have uninstalled it. Is there a fix for this ?
    Or do i go and get a new antivirus app.
    Also will turning off the real time protection from Windows Defender make any kind of a difference, I’m thinking no.
    I have avast on my laptop with no problem but that runs windows 7 and I have it on a another pc and that one is windows 10 and running with no problem. Only difference on the 2 desktops is one is Intel pentium chip and one is AMD Athlon dual core chip. The AMD computer is the problem one. Both desktops are HP desktops
    Thanks for any help I can get
    Reply To: Avast Free UI fails to load constant problem
