Hello,
This is a followup to the discussion about my USB mouse/ Sleeps issue on my HP Win 10 V1909 laptop. After that discussion here and one with my computer tech, I still have a few battery and power management questions.
In short, the issue was a black screen/not waking from sleep till the USB mouse adapter was either removed or plugged in – triggering the wake up.This is a relatively new issue – possibly since the last MS updates in early Feb – before that it worked fine for both sleeping and waking.
To try to correct that, both my tech and here at AW, it was suggested that I just disable the sleep function as that seemed to be the cause – some glitch in the wake part of the sleep setting.
So – I have turned off all sleep functions – just have the display set to turn off after inactivity. But this has brought up several battery/power related questions that I hope someone can help with.
- Will keeping the laptop on the charger for long periods – like overnight – or other times when I would usually let it sleep, cause battery issues?
- Is there any difference between setting up the sleep options in power management versus just manually clicking sleep in the start button? Would doing it manually change anything in the way it responds to waking up?
- I believe I had it set to wake when either the keyboard or the mouse were disturbed – should that possibly be changed?
- Are there settings to check to minimize the battery draining when idle but not sleeping?
- ย Is there any other “trick” anyone knows for waking a laptop that is sleeping and will not respond?
- Could this issue be caused by KB4535680? I was just checking the installed updates, and saw that it is listed twice in my update list. I am very careful to only install the recommended ones, and have that KB on my NOT list for February – but it is there already installed twice. At the beginning of Feb, I thought I had installed the Jan updates: KB4598229 and KB4598479, but only 4598229 is listed along with 4535680. Should I uninstall that one? Might it have been the cause of this issue all along?
I am concerned about allowing the laptop so just sit there, but not sleep, for the times when I am not using it during the day – sometimes several hours at a time. I don’t mind keeping it plugged in overnight, but I don’t want to have it run on AC power all of the time.
I appreciate any ideas on this issue. I know that sleep can cause problems, and just want to be sure that I am not doing more harm than good by turning off sleep completely.
Thanks!
