• Conditional Format based on adjacent cells being equal
    Home » Forums » AskWoody support » Productivity software by function » MS Excel and spreadsheet help » Conditional Format based on adjacent cells being equal
    Is it possible to conditionally format cells when the adjacent cell is equal to it? For example, if b170 = c170, then format one or both cells with some sort of shading?
    If so, how?
    Thanks!!
    Troy
    • #1432106
      Troy,
      To do this select the cells you wish to highlight then select Conditional Formatting -> Use Formula:
      35934-ConditionalFormatting
      Enter formula shown above (Use the second one as I entered it first. If you want both cells formatted select the adjacent range and then use the 1st formula shown as it was the second one I entered. I should have changed the order but I already made the screen capture and I’m sure you can adjust. Make sure you enter both = signs in the formula! HTH and Happy New Year! :cheers:
    • #1432158
      That worked well for the most part. Thanks!! The only downside I found is that this is not case-sensitive. For example, it shows “KM” and “Km” as identical. I still learned a lot, and appreciate the help with this!!
      I also tried a different method. In an empty column to the right, I put the following formula:
      =IF(B2=C2,TRUE)
      Then I filter the TRUEs.
      However, this does not appear to be case-sensitive either.
      Any ideas on how to make at least one of these methods case-sensitive or provide another method that is?
      Thanks!!
    • #1432163
      Actually, I just found a solution that works for the second method using “EXACT”:
      =IF(EXACT(B4242,C4242),TRUE)
      Is it possible to do that with conditional formatting? I tried but could not get that to work.
    • #1432166
      Just use: =EXACT(B4242,C4242)
    Reply To: Conditional Format based on adjacent cells being equal
