• Error handling problem from evaling code that raises error
    Home » Forums » AskWoody support » Productivity software by function » Visual Basic for Applications » Error handling problem from evaling code that raises error
    Hi all
    (Access 2002 VBA)
    I’ve got a need to catch errors that are raised from some code that is evaluated with eval. Here’s some sample code that displays my problem.
    Code:
    Function testFn()
        Err.Raise 100
        testFn = 5    ‘Correctly, this doesn’t get evaluated
    End Function
    Sub testEval()
        On Error GoTo ErrorHandler
        Dim result As Integer
        ‘Err.Raise 100    ‘If this was here, works as expected
        result = Eval(“testFn()”)   ‘This should raise error, but it is unhandled
        Debug.Print “Result is”, result
        Exit Sub
    ErrorHandler:
        ‘Should end up here, but doesn’t
        Debug.Print “Error”, Err.Number, “handled”
    The problem is that the error raised should be caught by the ErrorHandler, but it isn’t. Instead, VBA displays the familiar ‘run time error’.
    It doesn’t matter what my Tools>Options>General>Error trapping setting is.
    Should I be able to catch a raised error from eval’d code? If not, what are my other options?
    Naturally, MS documentation is of zero help.
    Thanks for any ideas.
    Peter
    • #1273094
      The error handler has to be able to traverse the call stack to locate the last active error handler when there isn’t one in the local routine. The Eval() function doesn’t manage the call stack the same as Call. This is evident if you press ctrl-L when in the function called via Eval() to see an example.
      The code below works correctly as it doesn’t need to reverse walk the call stack to locate the error handler.
      I’d suggest two options:
      1. Don’t use Eval()
      2. In Eval()’d routines, create local error handlers.
      Code:
      Sub testEval()
          Err.Raise 100    ‘Works as expected
          result = testFn(101)   ‘This should raise error and get handled
          result = Eval(“testFn(102)”)   ‘This should raise error, but it is unhandled unless local error handler active
          Exit Sub
      ErrorHandler:
          Resume Next
      Function testFn(ByRef errnum As Long)
          On Error GoTo LocalErrorHandler   ‘ Remove this line to generate run-time error
          Debug.Print “Call stack is? (Press ctrl-L)”
          Err.Raise errnum
          Exit Function
      LocalErrorHandler:
          Debug.Print “Error”, Err.Number, “handled locally in called function”
          Resume Next
      End Function
      PJ in FL
    • #1273169
      Thanks PJ. I was hoping it would manage the call stack, but as you have clearly shown it doesn’t.
      Yes, I’ll need to manage it locally.
      Thanks for the clear explanation.
      Peter
    Reply To: Error handling problem from evaling code that raises error
