• Help with Average Function (2003)
    Greetings,
    Had help with a subtotal function a while back.
    Background: I have a worksheet where I have set autofilters on. The Subtotal function works great to show me the total of items displayed when I filter the data. I would like to do the same with the Average function.
    Current for the Subtotal =SUBTOTAL(3,C4:C328)
    Current for the Average =AVERAGE(E4:E243)
    any ideas?
    Thanks,
    Brad
    • #1125069
      =Subtotal(1,E4:E243)
      [You might want to look at SUBTOTAL in the Help as it indicates the “function numbers” needed to give different statistical functions…]
      Steve
      • #1125070
        Steve,
        Thanks! Just looked at the help. did not even think to go there (or use subtotal function for average).
        Brad
        • #1125073
          Yes the “subtotal” is a little bit of a misnomer, but you should have guessed that when you used it to COUNT rather than to SUM… smile
          Steve
    Reply To: Help with Average Function (2003)
