Yesterday the boss brought his laptop in and wanted a file transferred from it to his work desktop (he’s very computer challenged). I booted it up (XP pro sp3) fine and when I put in my flash drive it seems to stall a bit installing it and then the mousepad became very erratic in its responsiveness. I decided to plug in his usb mouse but it wouldn’t power up. I ended up resetting the computer by holding down the power button. It seemed to boot ok but then the 3 blue squares in the load bar slowed right down to moving at a space per second and the drive activity light stopped. I left it like that for 10 mins but no change. Rebooted into safe mode ok so then tried a standard boot. No go. Tried a “Boot to last known good setting” Same thing. Booted back into safe mode, after checking flash on the desktop machine, inserted it into laptop and it was recognised properly. Copied the file I needed. Looked at Device manager, no issues showing there. Decided to try a system restore from a week ago, no good, laptop still won’t boot.
The fact I can get into safe mode ok means that it is most likely a driver issue. Where do I go from here?
