• Help with changing path names in hyperlink (200)
    Home » Forums » AskWoody support » Productivity software by function » MS Access and database help » Help with changing path names in hyperlink (200)
    Our server has just been swaped over and l cannot find a way of changing path names (these are in hyperlink data type format)
    What l would like to do is to replace the words PANTHER with LEOPARD. I have tried to change the data type to text but this did not work.
    Any help would be appreciated.
    • #1000023
      I haven’t heard of Access 200. Is it Access 2000, 2002 (XP) or 2003?
      • #1000024
        my mistake access 2000
        • #1000029
          1) Activate the Modules section of the database window.
          2) Click New.
          3) Copy the following code into the module window:
          Function MyReplace(varText As Variant, Find As String, What As String) As Variant
          If IsNull(varText) Then
          MyReplace = Null
          Else
          MyReplace = Replace(varText, Find, What)
          End Function
          4) Switch back to Access.
          5) Activate the Queries section of the database window.
          6) Create a new query in design view.
          7) Add the table with the hyperlink field to the query.
          8) Add the Hyperlink field to the query grid.
          9) Select Query | Update Query; this adds a row ‘Update to’ in the query window.
          10) Enter the following expression under Hyperlink in the ‘Update to’ row:
          MyReplace([Hyperlink],"PANTHER","LEOPARD")
          11) Select Query | Run.
          12) You should see a message that you are about to update … rows. Click Yes.
      • #1000026
        i have managed to changed the paths by replacing the hyperlink to text format, but for some odd reason the end of the hyperlink has been chopped and the link is invalid.
        see screenshot for what l mean.
        • #1000030
          See my previous reply for a way to update the hyperlink field through a query.
          You shouldn’t change a hyperlink field to a text field, the values will be truncated to the length of the text field, with a maximum of 255 characters. You can, however, change it to a Memo field, then replace PANTHER with LEOPARD, and finally change it back to a Hyperlink field.
          • #1000031
            Thats brilliant Hans,
            This will save me an awful lot of time.
            I get an error message, see attachment.
            • #1000034
              Specify the name of the table in the expressions, e.g.
              MyReplace([Beoing DRLs subtable].[Hyperlink],”PANTHER”,”LEOPARD”)
            • #1000035
              That works great thanks.
              You saved me a lot of time , l really appreciate that help.
          • #1000032
            I will try this way if l cannot get the query to work.
      • #1000027
        Shall l send you a zipped up version of the database?
        Once l know how it can be done with one table and l can do the rest.
    Reply To: Help with changing path names in hyperlink (200)
