• Help with Temp files that will not delete
    Home » Forums » AskWoody support » Windows » Windows 11 » Windows 11 version 23H2 » Help with Temp files that will not delete
    • This topic has 4 replies, 3 voices, and was last updated 1 year ago.
    I tried over and over again to delete these files in the temp folder and they will not delete. I have searched the internet and nothing is helping and i don’t know where they came from. They do not show up in task manager or anywhere else just the %temp% folder.
    Anyone know what they are and how to delete them? Thanks in advance.
    Windows 11 Pro
    Version 23H2
    OS build 22631.5189
    • #2663388
      APPX.*.tmp are for the most part created by Microsoft Store Apps running on UWP.  The TextInputHost.exe allows text input into a UWP app.  The APPX.*.tmp files can be used to reserve memory addresses for apps.
      • #2663407
        Ok, so which app do I choose to open them, notepad, firefox, windows media player legacy, or Browse apps in the MS Store and then set as default? So confused.
        Windows 11 Pro
        Version 23H2
        OS build 22631.5189
    • #2663415
      The AppX Deployment Service (located in Services) uses those files when the Microsoft Store finds and installs updates to the Store apps you have installed on your system.
      Normally, those files are deleted after the Store apps are successfully updated.
      There are several “temp” files that are in use by the system and can’t be deleted.
      I wouldn’t worry about it.
      • #2663417
        I did update store apps the other day, so they are the culprits! Thank you!
        Windows 11 Pro
        Version 23H2
        OS build 22631.5189
    Reply To: Help with Temp files that will not delete
