• How to set up wifi extender using a spectrum router that does not hav a wps butt
    Home » Forums » Networking – routers, firewalls, network configuration » How to set up wifi extender using a spectrum router that does not hav a wps butt
    I have been trying to find a wifi extender that will work with my spectrum router that does not have a wps button. I know that spectrum will rent one for $3.00 a month but I would rather purchase my own and not have to pay each month. I hope some one can help me. Thanks.
    Ralph
    • #2614223
      Does the router have a WPS connect option in the router settings? (Mine has, but it also has a WPS button.)
      • #2614301
        It’s still true
        Wi-FI Protected Setup (WPS) is Insecure: Here’s Why You Should Disable It
        WPA2 with a strong password is secure as long as you disable WPS.
        WPA2 with a strong password is secure as long as you disable WPS. You’ll find this advice in guides to securing your Wi-Fi all over the web. Wi-Fi Protected Setup was a nice idea, but using it is a mistake.
        Your router probably supports WPS and it’s likely enabled by default. Like UPnP, this is an insecure feature that makes your wireless network more vulnerable to attack…
      • #2614322
        I can not find the settings on my router.
    • #2614304
      I use the Tp-link  AC1750 Mesh WiFi Extender.  It has 3 different ways to set it up: Their app downloaded to a smart phone, or thru a web browser and their web site, or thru the router WPS button.  I set mine up with the app on my smart phone that is connected to the router via Wi-Fi.  It is real easy to set up, no WPS button used,  and is working great.  It uses the WPA2 security of the router.
      HTH, Dana:))
      • #2614323
        Thanks I just ordered one and in a couple of weeks I should know if it works for me.
    • #2614324
      I do not know how to do this and I really do not want to.
    Reply To: How to set up wifi extender using a spectrum router that does not hav a wps butt
