• Need General Procedure Overview on Using Macrium Reflect
    Home » Forums » AskWoody support » Windows » Windows – other » Need General Procedure Overview on Using Macrium Reflect
    My laptop is currently running Win8.1. I have recently downloaded Reflect free so I can do a better job of backing up my machine. I use iDrive for backing up my files but I would like to save computer images from time to time. Especially since I am planning to upgrade to Win10 before the end of July. Late yesterday I ran Reflect and saved a copy of the laptop image in my external 1TB hard drive. In that process I had several questions about which way to proceed. For example, the program seemed to be designed for using a on-going backup plan which I had not planned. Also, it asked me to enter a folder name and I didn’t know if it should reflect the current date or if the program would record the date in some other way.
    So, I would love to see an overview of how to make good use of a program like Reflect. Hopefully, there is a overview like that somewhere that someone can direct me to.
    Thanks,
    Bill
    Viewing 25 reply threads
    • #1566607
      I use Macriuim Reflect, free version, on a regular basis, and it works for me. Here’s how I use it.
      First, I have a dedicated external USB drive which holds the backups. This drive is only connected to the PC when actually doing a backup, or if I need to recover something. At all other times it is physically disconnected. My drive is designated as Drive I (for Image), so I will use that from now on.
      The first thing to do is to fire up the program and go to Other Tasks > Edit Defaults. Here you will define how you want the program to run. Most of the settings are intuitive, but under the Backup tab, the best settings are:
      Compression: Medium, with Intelligent sector copy.
      File size: Automatic
      Password: Up to you. I don’t use one.
      Auto Verify Image: Turn it on. It verifies that the backup image is a true copy of the disk being backed up.
      Verify File System: Before backup.
      Priority: Up to you. I use Highest, and don’t use the PC for anything else while a backup is running.
      In the Advanced tab, Enable file write caching may speed up the backups – or it may not. try it both ways.
      I have two physical fixed drives, and I back them up separately. On starting Reflect, I get a “backup” screen, with tabs for “Create a backup”, “Backup Definition Files” and “Scheduled Backups”. On the left of the screen there are “Backup Tasks: – “Image selected disks on this computer” and “Create an image of the partition(s) required to backup and restore Windows”. I select “Image selected disks”, and it shows me all the connected disks, except the one where Windows is installed. I select my second hard drive (Drive E), which is where my data resides. In the Destination section, the folder is just I:, then I uncheck the box that says “Use the image ID as the file name”, and I give the backup file a more meaningful name such as “E Backup June 7 2016”. The file suffix of .mrimg is appended automatically. Then, I don’t bother with the following “Next” screens. I just click Finish, then under Backup Save Options, “Run this backup now” is checked, but I uncheck the “Save backup…” bit. I don’t see the need for that. Then click OK, and it will do the backup and verify. This could take a while, depending on the amount of data to be backed up, and the transfer speed. When it is finished, I go back and do it again for “the partition(s) which are required to backup and restore Windows”.
      Following that procedure will give you an image backup of your disk(s), but you also need to know how to restore, if the need arises. You can restore the entire disk, for example if a software installation goes wrong and you want to revert to an earlier time, or you can recover individual files if you need to do that. I will describe restoring the entire disk first.
      Macrium provides two means of restoring an entire disk. If the system is bootable, but you want to restore it, you can boot into a special recovery mode. If you really clobbered something and it is no longer bootable, you can boot from a recovery disk. Both of these require some action to set them up, so do these things before you start backing up.
      To enable booting to recovery mode, go to Other Tasks > Add Recovery Boot Menu Option, and follow the prompts. It will create a new option at boot time; you can either boot into Windows (the default), or into the recovery environment, where you will see your backups and will be able to restore the one you want (this is why meaningful names are a good idea). To create a recovery disk, put a new CD in your optical drive and go to Other Tasks > Create Rescue Media, and again follow the prompts. NOTE – this option will only work if your BIOS (or UEFI) is configured to boot from the optical drive first. Booting from this drive will once again lead to the recovery environment, from where you can select a backup file to restore.
      To recover (or view) individual files, you can define a backup file as a “disk” in Windows Explorer or a similar program. To do this, switch to the Restore tab, then select “Open an image or backup file in Windows Explorer”. Select the backup file you want, and assign a drive letter to it. Then you can open Windows Explorer (or similar), and the drive letter you specified will show up as just another disk drive, from where you can copy files or do whatever you want. When finished, “Detach a backup image from Windows Explorer”.
      A couple of other points to note: (1) Don’t let your backup disk get too full. There is no point in keeping backups which are more than a few weeks old. I do my backups every weekend, and I keep about four or five weeks worth. Before I back up, I delete the oldest backups. (2) It really helps if both your PC, and the receiving backup disk, can use USB 3. With USB 2, one of my backups used to take 35-40 minutes, but with USB3, the same backup takes about eight minutes.
      I hope this is what you wanted to know. I’m happy to answer any further questions. I might add that on more than one occasion I have needed to restore my C drive because something got hosed, and it has worked flawlessly every time. BTW I am running Win7, soon to upgrade to Win10, and if I don’t like 10 I expect to easily restore Win7 from backup.
      • #1566608
        I like to uncheck – Purge the oldest backup set(s) if less then 5 GB on the target volume.
        • #1566610
          “I like to uncheck – Purge the oldest backup set(s) if less then 5 GB on the target volume.”
          “Compression: Medium, with Intelligent sector copy.”
          Early on, I disabled the entire purge board; I do my own purging 🙂
          Early on, I use High compression, with Intelligent sector copy. To save bytespace on the 1TB ex HDs.
          Bundaberra — a great job describing the process!!
          I’ve never scheduled a backup; I’ve always done on the fly, live, backups 🙂
          Now, anyone scheduling backups, great! Just now and then, verify a scheduled backup image actually exists and is restorable [via verify function].
    • #1566662
      I’m a Macrium Reflect person also and this is an excellent thread. I’m happy to know I’m doing most of the recommendations and I’m learning a few new things myself.
      I manually do my backups on a monthly basis and have the external hard drive disconnected in the meantime.
      I’ve been wondering about the “I like to uncheck – Purge the oldest backup set(s) if less then 5 GB on the target volume.”
      — I uncheck it because I don’t expect to get to the “less then 5 GB on the target volume”.
      — I prefer to keep only 1 prior backup: I use to keep 2 and I will go back to that if it’s a better idea in your minds. I have tested my backups a couple of times and each time everything was fine.
      — But what I haven’t figured out yet is how to do my own purging .
      — Advice will be appreciated on that
      As RolandJS mentioned “Bundaberra — a great job describing the process!! “.
    • #1566665
      You already have a detailed explanation of a method from Bundaburra, but I’ll throw in my two cents, and it applies to almost any decent backup program.
      Reflect, like many backup programs, can do both scheduled and unscheduled backups. It can also do different types of backups (incremental, differential, full). Which of these you choose is entirely up to you and depends on how much data you are backing up, what your backup media is, and your personal needs.
      There have been reams and reams written describing complex backup plans with rotating media and off site storage. At one time, that was the norm because backups took hours to run and media largely consisted of tape drives that were sized in MB rather than GB. This was also a part of most responsible businesses disaster recovery plans. Today, with multi-terabyte external drives that will fit in a pocket and cloud storage, many of the old ideas have been set aside.
      Depending on your needs, you can do a full image once a week or once a month. Just be sure that you image before any significant updates. Spend a few bucks for a small drive (or flash drive) and a good fire-resistant box. Put it someplace well away from your computer and put your most recent image there.
      Also, there are a number of ways to get 2-5gb of cloud storage free. This is enough to backup critical documents – think of it like a safe deposit box. I keep a few compressed and encrypted files in the cloud, just in case. No matter what happens, I can retrieve them.
    • #1566710
      Has it even dawned on anyone, that any Backup and Restore program that runs on your C: drive is 100% busted, when that drive squalls, howls and smokes? (also known as CRASHING)
      It would seem, NOT!
      I’ve set up backup/restore systems for casual users, businesses, Corporations, and even Govt agencies and in every case, my Backup/restore program was on a bootable CD.
      And the location for my backups was a separate hard drive, just to keep it close, and quickly accessible if needed.
      You can’t access the “cloud” when your PC has crashed. At that point, you can only boot up from a CD or Flash Drive.
      (after replacing the crashed HD, with a new one)
      I keep my own “Ghost Backups” on both an internal 1TB HD and an external 1TB, USB 3.0, hard drive.
      And, I make a new backup of C: at least once a week. My data files are backed up daily, using a batch file and XCOPY.
      At least twice a year, something gets into my PC and makes a mess of my OS, , , , then it only takes me about 15 minutes to restore my last Ghost backup of my C: drive, to put things right again.
      Good Luck y’all!
      The Doctor 😎
      • #1566711
        It would seem, NOT!
        Actually, Bundaburra said that very thing:
      • #1566717
        Uuummm… yes. Good programs (like Reflect) come with software that can create a boot disk or USB with which to restore from an image. Part of any good back strategy is to test this boot device and keep it up to date with any driver changes, if needed.
        • #1567199
          Would you update the Macrium Reflect Boot Disk (mine is on a USB Flash Drive) for “every” driver change?
    • #1566723
      gsmith-plm
      An excellant point. We’re apparently in agreement on such things. 😀
      Image or Clone often! Backup, backup, backup, backup......
      Home Built: Windows 10 Home 64-bit, AMD Athlon II X3 435 CPU, 16GB RAM, ASUSTeK M4A89GTD-PRO/USB3 (AM3) motherboard, 512GB SanDisk SSD, 3 TB WD HDD, 1024MB ATI AMD RADEON HD 6450 video, ASUS VE278 (1920x1080) display, ATAPI iHAS224 Optical Drive, integrated Realtek HD Audio
    • #1566724
      FWIW here’s a link to a How-To-Geek article with pictures! :cheers:
    • #1566735
      Macrium has features which I don’t use, because I find them unnecessary. I don’t do scheduled backups, I prefer to run them manually, at a time that suits me. And I have no concept of “backup sets”. As I said previously, I write the xxxx.mrimg files to an external drive. Each file is named with the source of the backup, and the date taken. I do weekly full backups, and I keep the last four backups for each drive, but I would rarely, if ever, want to back up from four weeks ago. Before I run a backup, I just manually delete the oldest files on the backup disk. The disk is always less than half full.
      The Restore option to boot into a special recovery mode puts an extra boot option on the startup screen. It’s like where you have multiple operating systems, and it asks which one you want to run. Booting into Windows is the default, and you can reduce the amount of time that the Recovery option is displayed, if it annoys you, by running Msconfig > Boot, and reducing the Timeout to a low number like 2 or 3 seconds.
      • #1566742
        “…Has it even dawned on anyone, that any Backup and Restore program that runs on your C: drive is 100% busted, when that drive squalls, howls and smokes? (also known as CRASHING) It would seem, NOT!…” — DrWho
        I just awoke from my TV-nap, I’m missing something here. On each of my three computes, weekly or bi-monthly, I make at least two full images of the OS partition, one on each of the two dedicated usb ext HDs [for each pc]. I do these normally when Windows sessions are running about as right as rain. And having two usb ext HDs, I don’t expect both to fail at the same time, physically or logically.
    • #1566740
      “…But what I haven’t figured out yet is how to do my own purging…” cmptrgy
      What I do is plug in the two usb ext HDs into the computer, use explorer.exe to give me directories. Going through the directories, I can delete any old backup on both drives in moments, after Safely Remove Hardware/Eject Media gives me the all clear – unplug and “reSafe” the two HDs.
    • #1566807
      WOW, I’ve received a lot of useful info in the last 24 hours! Thanks Bundaberra for your detailed description of how you do it. That will be a big help to me. Thanks also to RG for the link to the How-to article. I had looked there for something like that before I started this thread but I obviously didn’t search for the right key words. Thanks to everyone who contributed to this thread. I’ll try this out in the next few days.
      Bill
      • #1566998
        Obviously, everybody’s backup procedure differs. Mine is like this:
        1. I run a Windows Home Server and use Drive Extender to allow files to be duplicated and kept automatically on 2 separate drives. So, a form of backup there.
        2. I keep an ESATA 2 TB HD attached to the server and backup the server twice a month to that drive (keeping multiple twice/month generations on that drive).
        3. Once per month I stick a standalone 1 TB drive into the server, take a backup and remove the drive again.
        4. The drives used in step 3 are used on a father/son basis where one is stored in the house and one stored at my son’s house (just in case of fire/theft in our house).
        I did use Macrium Reflect to image the PCs in the house before the Win10 upgrade but just on a one time image basis to a separate USB hard drive.
        As all my data files reside on the server, upgrading the PCs to Win10 was relatively painless. Now, replacing the sever one day might take a little more work .
        The PCs themselves backup to the WHS also.
        K
        Bill
    • #1566809
      I’ve just been reading through the How-To-Geek article and I see what it says about using the correct version of Windows PE when creating the Reflect Rescue media. I didn’t pay enough attention when I passed that step last night when I made my Rescue media so I don’t know if I have the right Windows PE or not. The example in the How-To article seems to imply that the default choice is based on Win7 but I am running Win8.1. Should I make it over again?
      Thanks,
      Bill
    • #1566823
      BillWilson, yes, try again. I thought it would default to the “sniffed” OS, however, try setting that thingie manually and please report back — I might need to finetune mine over here.
    • #1566855
      Bill,
      It’s been my experience that if you use the latest version of Win PE it will work on older machines just fine. I just make my Bootable USB keys using PE 10.0 and I have found it works just fine for restoring Win 10, 8.1, and 7. Remember you are booting from that USB and as long as it understands the Disk Formatting protocols (MBR/GPT) there shouldn’t be a problem as both Windows and Macrium are running off of that USB drive. So just make your USB Bootable devices on the machine with the Newest OS and you should be good to go.
      Of course you’ll want to test it’s bootability on all the machines on which you plan to use the device!.
    • #1566972
      I found that I have a small (1GB) thumb drive and the Reflect Rescue drive does not need much space so I created a new Reflect Rescue drive on it. During that process it did pick the Windows PE that goes with Win8.1 so I imagine my previous Reflect Rescue drive was made that way too. The new Rescue drive does boot-up OK too. So, I seem to be in good shape on this subject for now.
      Thanks to those who contributed to this discussion.
      Bill
    • #1567062
      I have a relatively new HP that was designed for and came with Windows 10 installed. The safe boot feature wouldn’t let me boot form the Macrium boot CD. The CD would spin up a few times, but Windows would override it and load Windows 10.
      Ii spent (wasted) a lot of time with HP support trying to solve this issue. At one point support suggested that the machine was defective and wanted me to return if for servicing!
      The solution is Settings > Update & security > Recovery > Restart Now >Choose device. Choose the CD drive and Windows will boot to it. (Once you select Restart Now, you’re going to restart, no matter what.)
      I once had a permission problem with Adobe software when I was running Windows 7. I created several image files: one for photo editing (including all my photos), one general-purpose image, and one up-to-date Windows 7 image with no programs. I had three external drives where I saved these, but ultimately two of the drives failed at the same time, and I still haven’t restored my photos completely. (i got most of them back from IDrive.) I only have one image now, but I still use three (new) backup drives. Of course, if you only have one backup image, it’s unlikely that your hard drive and your external drive will fail simultaneously, but one never knows, do one?
      Macrium had a sale on the full program, so I bought it. One security feature is encrypting backup files. There are lots of other features unlocked, but I don’t use them.
      • #1567123
        This is the reason for having multiple generations of backup on different hard drives.
        With hard drives it’s NOT a matter of IF they fail but WHEN. They will all fail eventually.
        K
    • #1567068
      One thing nobody mentioned is that you need to match the “bittedness” of Macrium with your PC; i.e. if it is running 32-bit Windows use 32-bit Macrium.
    • #1567206
      Not necessarily “every driver” but for significant specific drivers (having a bearing on the operation of Macrium Reflect perhaps?).
      In other words, if the version of Macrium you use changes, it would be prudent to re-create your bootable disk (CD/DVD/flash drive, etc.).
      Expanding on what gsmith-plm said (I hope he doesn’t mind my “paraphrasing”): make sure it boots, test it, make sure it works. That’s what counts.
    • #1567213
      Steven,
      Basically the answer IMHO is NO. You should however definitely update the USB is your Network Drivers change and you are using a networked device as the target for your Image/Backup files. I had trouble initially using a WD NAS drive (they are slow anyway compared to USB) as it wouldn’t show up in the file browser. I did manage to load custom drivers but it was a pain. Later I found out that if I just entered the server name in the searchbox, e.g. \MYBOOKLIVECMShared everything worked just fine no need for custom drivers any more.
    • #1567262
      Why don’t you make an image, upgrade to W10 (make sure it activates), then revert to W8. Now you can upgrade any time you want to and don’t have to worry about the deadline.
      • #1567349
        Hi Paul,
        If you talking to me (?), I have upgraded to Win10. Seems to have settled down. I only saw that one BSD (so far ), so will stick with Win10.
        K
        • #1567364
          you talking to me?
          It was for Bill actually. 🙂
      • #1567455
        Why don’t you make an image, upgrade to W10 (make sure it activates), then revert to W8. Now you can upgrade any time you want to and don’t have to worry about the deadline. cheers, Paul
        That sounds like a good approach.
        I’ve had some indications that my laptop might be infected so I’ve spent many hours doing scans. Malwarebytes did not find anything so I thought I would run another one too and I tried ESET and it ran and said it found 2 problems but it never finished. After repeating that twice more it finally did finish by aborting so I never did know what it had found. So, I ran Trend Micro in the Quick scan mode and it didn’t find anything. Then I ran it again in the normal scan mode and that took at least 36 hours to finish! It said it had found 4 problems and displayed a list of them. Just looking at the list I could tell that 3 of them were already quarantined by my normal antivirus but my laptop froze up before I could find out anything more about the 4th one. I finally had to force a shutdown. So now I’m hoping when I reload Trend Micro I might get lucky and find that there is a log file from the aborted run.
        Thanks for the suggestions.
        Bill
    • #1567346
      And don’t forget to make yourself a Macrium Reflect bootable Recovery Disk to use if your system becomes unbootable!
      My Rig: AMD Ryzen 9 5900X 12-Core CPU; ASUS Cross Hair VIII Formula Mobo; Win 11 Pro (64 bit)-(UEFI-booted); 32GB RAM; 2TB Corsair Force Series MP600 Pro 2TB PCIe Gen 4.0 M.2 NVMe SSD. 1TB SAMSUNG 960 EVO M.2 NVME SSD; MSI GeForce RTX 3090 VENTUS 3X 24G OC; Microsoft 365 Home; Condusiv SSDKeeper Professional; Acronis Cyberprotect, VMWare Workstation Pro V17.5. HP 1TB USB SSD External Backup Drive). Dell G-Sync G3223Q 144Hz Monitor.
    • #1567495
      I’d get the machine cleaned before upgrading. Have you used one of the offline scanners from Panda or Kaspersky?
    • #1567520
      No I haven’t used either one of those two on this machine. I’ve used Kaspersky at some point in the past.
      After installing Trend Micro (free) it did give me a log file display from the most recent run. The 4th thing it found turned out to be an Adware thing, not an actual virus. I deleted everything in my normal (Comodo) antivirus quarantine so all 4 of those have been accounted for. I’ll go ahead and run one of the two you suggested too.
      Thanks,
      Bill
    • #1567642
      FYI. the newest version of MRF 6.1.1311 offers differential only not incremental. I am assuming from comments here that it used to include both as an option.
    • #1567645
      @jcgc50 “FYI. the newest version of MRF 6.1.1311 offers differential only not incremental. I am assuming from comments here that it used to include both as an option.”
      According to the MR manual, incremental images are included in the paid version.
    • #1567646
      I don’t recognize “MRF”. Maybe you can educate me.
      Thanks,
      Bill
    • #1567647
      @jcgc50 I found the Feature Comparison table
      http://www.macrium.com/reflectfree.aspx
      @BillWilson MRF is Macrium Reflect Free
    • #1567657
      Thanks for the info. I’ll have to get more familiar with some of those features.
      Bill
    Reply To: Need General Procedure Overview on Using Macrium Reflect
