• Need help with simple macro
    hi all, I have the following code which isnt working because the “piece” range in the collection fails on the Piece.copy method. I cant think of what I am doing wrong. Help appreciated!!
    cheers,
    Dom
    Code:
    Public Sub GenerateDocument(Tag As String)
        Dim createdDocument As Document
        Dim outputContent As New Collection
        Dim i As Integer
        Dim piece As Range
        ‘Select the document
        ActiveDocument.Range(Start:=0, End:=ActiveDocument.Content.End).Select
     On Error GoTo err:
        ‘find all the matching bits
        With Selection.Find
            .ClearFormatting
            .Text = “[” + Tag + “]*[/”
            .Replacement.Text = “”
            .Forward = True
            .Wrap = wdFindStop
            .Format = False
            .MatchCase = False
            .MatchWholeWord = False
            .MatchAllWordForms = False
            .MatchSoundsLike = False
            .MatchWildcards = True
            While .Execute
               outputContent.Add (Selection.Range)
            Wend
        End With
        ‘ create a new document
        Set createdDocument = Application.Documents.Add
        ‘put the content in it
        For Each piece In outputContent
            piece.Copy
            createdDocument.Range.Paste
        Next piece
        Exit Sub
    err:
       MsgBox “GenerateDoc: ” & err.Desciption
    • #1435211
      I think it’s because “piece” is defined as a range, not content, and you are trying to copy the range instead of selecting it and copying the selection.
      • #1435322
        Nope, that can’t be the problem.
        The first line of the following fails saying that the object doesnt support the method. so Piece is always nothing. OUtputContent is full of all the stuff I need to paste into a different document.
        Code:
                piece.Copy
        Next piece
        if I do
        Code:
            For i = 1 To outputContent.Count
                outputContent(i).Select
                Selection.Copy
            Next i
        instead, then the select fails.
    • #1435339
      Why are you stuffing everything into a collection and then pulling it out again? It’s more efficient (and has fewer mysterious problems) if you just transfer each piece as you find it.
      There are other things here to think about. First, using Selection.Find forces Word to scroll and render pages, which slows the execution — often by an order of magnitude. Instead, use a range object’s .Find, which doesn’t cause any scrolling. Second, your pasting would put all of the found items one after the other, without any intervening space or paragraph mark. Third, each pasted item will end with an incomplete tag, just the left bracket and the slash.
      Try this replacement:
      Code:
          Dim rg As Range
      '    Dim destRg As Range ' see "alternatively" comment below
          Set rg = ActiveDocument.Range
      '    Set destRg = createdDocument.Range
       On Error GoTo err:
          'find all the matching bits
          With rg.Find
              .Text = "[" + Tag + "]*[/"
              .Forward = True
              .Wrap = wdFindStop
              .Format = False
              While .Execute
                 createdDocument.Range.InsertAfter rg.Text & vbCr
                 ' alternatively, to include formatting:
      '           destRg.FormattedText = rg.FormattedText
      '           destRg.InsertAfter vbCr
      '           destRg.Collapse wdCollapseEnd
              Wend
          End With
          Exit Sub
      err:
         MsgBox "GenerateDoc: " & err.Desciption
    Reply To: Need help with simple macro
