• Outlook Object Library Does Not Switch Between Versions 12 And 14
    Home » Forums » AskWoody support » Productivity software by function » MS Outlook and email programs » Outlook Object Library Does Not Switch Between Versions 12 And 14
    I have a .dotm template file on a network share. There are macros with references to the Word, Office, and Outlook object libraries. We use two different platforms, Windows XP and Windows 7, along with Microsoft Office 2007 and Office 2010. When users open the template file the references for Word and Office adjust automatic and accordingly (that is, they’re set to Microsoft Word 12 Object Library or Microsoft Word 14 Object Library as needed), and the macros run without a problem.
    Microsoft Outlook Object Library switches properly from version 12 to 14. It does not switch properly from version 14 to 12. In that case, it gives the error that the libary is not found. Is this a bug? Is there a workaround? Something I’m overlooking?
    Reply To: Outlook Object Library Does Not Switch Between Versions 12 And 14
