• Problem upgrading HP z440 to Windows 10. Problem with C drive partition.
    Home » Forums » AskWoody support » Windows » Windows 10 » Questions: Win10 » Problem upgrading HP z440 to Windows 10. Problem with C drive partition.
    I created a bootable usb drive using the Windows 10 media tool. I booted the z440 using the flash drive.
    I chose the option to erase the C drive and install a fresh operating system.
    The Windows 10 upgrade process could not find a driver so it could not find the C drive.
    The Windows 10 process prompted me for a driver. I found a driver.
    The Windows 10 process then said it could not continue because the C drive partition was an MBR and Windows 10 requires a GBT. I decided to delete the C drive partition. Then I could click on New and create a new partition. Unfortunately the Windows 10 upgrade process cannot change the partition type.
    So, what to do now?
    – I could restore Windows 7 pro, then format the C drive using Windows 7 pro to the correct partition type. Then, of course, Windows 7 pro would not be able to reboot because the operating system would be gone.
    – I could buy another drive, format it to the correct partition type and then remove the current C drive and install the new one in its place. The C drive would be completely empty and I don’t know whether the Windows 10 update process would accept this . I don’t really want to spend the money to buy another drive .
    How would you solve this problem?
    • #2321435
      From How to convert a disk from MBR to GPT format:
      Converting to GPT format using Command Prompt in Windows Setup
      Power off the PC, and insert/connect the Windows installation DVD or USB key.
      Power on the PC and tap F12 key until One-Time Boot Menu appears.
      Select the Windows installation DVD or USB in the menu and press Enter key.
      From the Windows Setup screen, press Shift + F10 key to open a Command Prompt window.
      In the Command Prompt window, type diskpart and press Enter key.
      To identify the disk drive to reformat, type list disk and press Enter key.
      To select the drive and reformat it, type select disk # (substitute # with the actual disk number e.g. select disk 1) and press Enter key.
      Type clean and press Enter key.
      Type convert gpt and press Enter key.
      Type exit and press Enter key.
      Close the Command Prompt window. If you are installing Windows, continue with the Windows Setup process.
    Reply To: Problem upgrading HP z440 to Windows 10. Problem with C drive partition.
