• Problem with 2nd combo box (2000)
    • This topic has 32 replies, 3 voices, and was last updated 21 years ago.
    Hello again guys ,
    Need your help again..
    I have attach 2 combo box on my usefrom to fill data in my work
    The problem is my 2nd combo boz didnt do what it suppossed to do like
    the 1st combo box did..
    Whats wrong with it ? Could you guys please help me again..thanks
    ps : plz refer to attachment
    • #827865
      Delete the routine UserForm_Initialize2() and incorporate it into UserForm_Initialize()
      Private Sub UserForm_Initialize()
          With cboposition
              .AddItem "20"
              .AddItem "30"
              .AddItem "40"
              .AddItem "50"
          End With
          With cboposition2
              .AddItem "Exams 1"
              .AddItem "Exams 2"
              .AddItem "Exams 3"
              .AddItem "Exams 4"
          End With
      • #827867
        Thanks tony. it works like charm ..
        • #827873
          ok..2 more thing before i forgot
          no 1 – Let say if i want to use the combo box and link it to some range let say
          the 1st combo box i want it to link with my range “pupils” that is a1:a4
          and so do the 2nd combo boz with my 2nd range “exams” b1:b4
          no 2 -Is it possible while on my userform , every time i want to go to the next
          combo box or text box , i simply can hit enter and it will go to the other box or
          combo box , because now , when i hit enter , it goes straight to the command button “OK”
          and not going to the next text box or combo box
          How do i do that..thanks again
          • #827882
            1/ With named ranges called Pupils & Exams, use the following code
                Dim MyRange As Range, MyCell As Range
                Dim MyRange2 As Range, MyCell2 As Range
                Set MyRange = Range("Pupils")
                Set MyRange2 = Range("Exams")
                For Each MyCell In MyRange
                    cboposition.AddItem MyCell.Value
                Next
                For Each MyCell2 In MyRange2
                    cboposition2.AddItem MyCell2.Value
                Next
            2/ To set the tab order, select the form in the visual basic editor and choose “View>Tab Order” from the menus.
            • #827900
              Thanks again tony for the prompt reply and it works with combo boxes and the range..
              But i can’t find the tab order in the vba editor by by clicking properties of the user form.what i found is just tag and not tab..any idea ? thanks again
            • #827904
              1/ In the Forms section make sure the object is displayed rather than the code, then select “View>Tab Order” as per the image
            • #827906
              thanks for the picture tony..it helps..my problem solved ..thanks to you tony..regards..
            • #827907
            • #827905
            • #829261
              Hello again tony..
              I have try to populate range from your code..but it shows nothing….empty..
              i pull the range from other sheets..is that why it dont show the list..
              thanks..any idea ?
            • #829263
              This is the code that i try to run..it works..but the list from the range dont show anything..
              When i select the combobox , its empty inside..
              Private Sub cmdCancel_Click()
              guru.Hide
              Private Sub cmdOK_Click()
              ActiveSheet.Unprotect Password:=””
              Range(“d2”).Value = cboposition6.Value
              Range(“d3”).Value = cboposition7.Value
              Range(“t2”).Value = cboposition8.Value
              Range(“t3″).Value = cboposition9.Value
              ActiveSheet.Protect Password:=””
              Unload guru
              Private Sub guru_Initialize()
              Dim MyRange6 As Range, MyCell6 As Range
              Dim MyRange7 As Range, MyCell7 As Range
              Dim MyRange8 As Range, MyCell8 As Range
              Dim MyRange9 As Range, MyCell9 As Range
              Set MyRange6 = Range(“Teacher”)
              Set MyRange7 = Range(“Year”)
              Set MyRange8 = Range(“Total”)
              Set MyRange9 = Range(“Type”)
              For Each MyCell6 In MyRange6
              cboposition6.AddItem MyCell6.Value
              Next
              For Each MyCell7 In MyRange7
              cboposition7.AddItem MyCell7.Value
              Next
              For Each MyCell8 In MyRange8
              cboposition8.AddItem MyCell8.Value
              Next
              For Each MyCell9 In MyRange9
              cboposition9.AddItem MyCell9.Value
              Next
              any comment..appreciated..thanks
            • #829284
              Perhaps most of this can be done by setting the ControlSource property of the text boxes and combo boxes, and the RowSource property of the combo boxes. See attached version of the spreadsheet you posted earlier.
            • #829304
              Thank hans..
              this is your statement : ” Perhaps most of this can be done by setting the ControlSource property of the text boxes and combo boxes, and the RowSource property of the combo boxes.”
              How do i do that ? thanks again
            • #829305
              Thank hans..
            • #829317
              See the spreadsheet I attached to my previous reply, and the screenshot below. The ControlSource of one of the combo boxes has been set to a cell on GlobalKelas, and the RowSource to a named range.
              ControlSource is the cell that is populated with the item selected in the combo box.
              RowSource is the range that supplies the list items.
            • #829330
              Hehe..thanks Hans..
              I think ..i’m getting understand a little bit about this..
              will try it first and then will make follow up if i want to know more ..thanks again
            • #829504
              At 1st this thing works smoothly..but when i go to 2nd combo box, try to fill data in cell d3..this error shows..what i
              have done wrong..please refer to attachment..thanks
            • #829506
              This is the file that i got the error after using hans method..thanks..
            • #829556
              I think i found the solution……
              My mistake..hehe…sorry guys..thanks a zillion
            • #829557
            • #829507
            • #829505
            • #829331
              Hehe..thanks Hans..
            • #829318
            • #829285
            • #829264
              guru.Hide
              Unload guru
              Next
              Next
              Next
              Next
            • #829262
              Hello again tony..
              thanks..any idea ?
            • #827901
          • #827883
                Next
                Next
        • #827877
      • #827868
    • #827866
          With cboposition
              .AddItem "20"
              .AddItem "30"
              .AddItem "40"
              .AddItem "50"
          End With
          With cboposition2
              .AddItem "Exams 1"
              .AddItem "Exams 2"
              .AddItem "Exams 3"
              .AddItem "Exams 4"
          End With
    Reply To: Problem with 2nd combo box (2000)
