• Problems with macro
    • This topic has 4 replies, 2 voices, and was last updated 15 years ago.
    Hi there
    I have written a macro and on the workbook I have on my machine it works great – macro below – however, my client has problems, so he emailed the workbook back to me.
    He opened it in 2007 but saved it as 2003. There are 3 worksheets with the same macro and on 1 it works great, but on the other 2 I get an error. The line oCell.EntireRow.Hidden = True is the problem here. Why would it work on 1 sheet and not on the other 2 sheets ?? On the copy I received from him, it indeed doesn’t work for me too.
    It has me baffled…
    Please help – Thanks heaps
    The macro is
    Private Sub Worksheet_Change(ByVal Target As Range)
    Dim oCell As Range
    If Not Intersect(Range(“d5:d400”), Target) Is Nothing Then
    For Each oCell In Intersect(Range(“d5:d400”), Target).Cells
    If oCell.Value = “Yes” Then
    Next oCell
    • #1224112
      Do you get an error? If so, which and on what line of the code?
      • #1224165
    • #1224170
      Yes, the line is
      and the message sayd “Run-time error 1004 – Unable to set the Hidden property of the Range class”
    • #1224252
      The code as such is OK, so something else is going on here.
      Maybe the worksheet in question is protected?
      What if you try to hide the row manually?
    Reply To: Problems with macro
