• Right-click filter
    If I open the db with the Return Key I can right-click an entry on a form and filter by form. If, however, I open the db without the Return Key this feature is disabled. I presume this is a settings issue somewhere (2007), but I can’t find it. Little help?
    • #1183390
      Did you mean the Shift key instead of the Return key?
      You can view and change the startup options for the database as follows:
      – Open the database with the Shift key held down.
      – Click the Office button.
      – Click Access Options.
      – Click Current Database in the left hand pane.
      • #1183412
        Ooops, yes I mean the Shift key and not the Return key. I did look through the options but didn’t see anything that would turn on or off the right-click functionality.
      • #1183417
        This was unchecked. All is well now. . .thanks!
    • #1183391
      I can’t open any databases in 2007 with the Return Key so I can’t investigate this properly. The Return Key opens them in 2003 on my computer.
      But I can use right click filtering, and I don’t think I have done anything special to make it possible. I get a right click menu like this:
      I only get it when the control is enabled.
      If you don’t use the Return Key, how do you open the database? There are a number of ways of opening a database so I am wondering which method you use.
      • #1183414
        Sorry John, I meant the Shift key, not the Return key. I hold down the Shift key and click on the db shortcut. If I don’t use the Shift key, I don’t get the menu you attached; if I do open the db with the Shift key held down, I get the menu.
        • #1183419
          Make sure that “Allow default shortcut menus” under “Toolbar Options” is ticked.
          Added: too late!
          • #1183422
            Added: too late!
            Never too late. Thanks!
    Reply To: Right-click filter
