• Right click scan with.. disappeared
    Home » Forums » AskWoody support » Windows » Windows 7 » Questions: Windows 7 » Right click scan with.. disappeared
    • This topic has 4 replies, 3 voices, and was last updated 15 years ago.
    My right click scan with (eset nod 32) has disappeared from my context menu. Has any one come across anything similar. I have searched and googled to no avail, Win 7 32bit ultimate. Thanks GWS.
    • #1219640
      If there is not a repair option, have you tried uninstalling and reinstall NOD32?
    • #1219688
      Hi Joe, Yes I am sure I can repair it and likewise reinstall nod32, however I wondered if anyone had come across this before and perhaps had a simple solution. Thanks for your reply though. Cheers GWS.
    • #1219695
      Check your settings … under the “enter entire advanced setup tree” make sure you have the “Integrate into the context menu” checked in the User Interface section.
    • #1220120
      Thank you Greg, I checked and it was ticked so I un-ticked it and rebooted and then re-ticked it and rebooted unfortunately still the same.
    Reply To: Right click scan with.. disappeared
