• Searching for a string (letters and numbers) (Word 2003)
    Home » Forums » AskWoody support » Productivity software by function » MS Word and word processing help » Searching for a string (letters and numbers) (Word 2003)
    I am attempting to search for a string of characters similar to the following: 10.1(a)(iii). The following wildcard search string works for strings similar to 10.1(a): [0-9][0-9].[0-9]([abc])
    However, when I add the second ([abc]) it fails. I also tried using ([abc]){1,2} with no success. Any ideas on how I can use wildcards to find the string 10.1(a)(iii)?
    Thanx in advance… trish
    • #1056399
      The lower-case Roman numeral i is not in the range a-c. Roman numerals can use i (1), v (5), x (10), l (50), c (100), d (500) and m (1000). So you must either specify these characters or allow the entire alphabet.
      Strict: [0-9]{2}.[0-9]([a-z])([ivxlcdm]{1,})
      Sloppy: [0-9]{2}.[0-9]([a-z])([a-z]{1,})
    Reply To: Searching for a string (letters and numbers) (Word 2003)
