• shortcut not using specified workgroup (97)
    Home » Forums » AskWoody support » Productivity software by function » MS Access and database help » shortcut not using specified workgroup (97)
    I created a desktop shortcut to my mdb & specified a workgroup on the server it is to be opened with. But the logon box says I
    • #539662
      Arage,
      You have to add the access.exe part in your shortcut
      “C:Program FilesMicrosoft OfficeOfficeMsAccess.exe” “H:dataSecure OACO.mdb” /wrkgroup s:/oaco/OACO.mdw
      if MsAccess.exe is in this default directory, else change the path to where you have installed the MsAccess.exe.
      Francois
      • #539674
        thanks Francois that helped but I get the following error now.
        What I did was to create a new shortcut & apply the command line criteria, somehow the /wrkgroup parameter is causing this error it says
        • #539679
          Sorry, you may me bash
          I was looking at the beginning of the command line and not to the end:
          “C:Program FilesMicrosoft OfficeOfficeMSACCESS.EXE” “H:dataSecure OACO.mdb” /wrkgrp s:oacoOACO.mdw
          The parameter is /wrkgrp and not /wrkgroup.
          Francois
          • #539683
            Francois,
            I sure hope by your last post you meant that I should be typing /wrkgroup, not /wrkgrp. You know why? B/c my book (access2k) says type /wrkgroup!
            But anyway, I tried /wrkgrp & it worked except now I get an error that the .mdw cannot be found in the path I specified, but it IS there in that location on the s: drive! Now what?
            • #539699
              not really.
              S:oaco is actually S:O A C O & I
            • #539706
              Do you mean that there are space in your path ?
              Then you have to enclose the path in quotes like in the first and second part.
              “C:Program FilesMicrosoft OfficeOfficeMsAccess.exe” “H:dataSecure OACO.mdb” /wrkgroup “s:o a c oOACO.mdw”
              Let’s have another try
              Francois
            • #539759
              temporary victory Francois your advice worked, but I
            • #539765
              What a space can do!
              Now we have solved a space problem, do you think we are member of NASA ? laugh
              To see what MDW file you are using, the only way I have found so far, is to open a module, go to the immediate window and type:
              ? dbengine.systemdb
    • #539695
      Maybe
      /wrkgroup s:oacoOACO.mdw
      instead of
      Francois
    Reply To: shortcut not using specified workgroup (97)
