• Some links in web pages will not load
    Home » Forums » AskWoody support » Windows » Windows 7 » Questions: Windows 7 » Some links in web pages will not load
    I have reinstalled windows with the no format reinstall, stopped Lmhosts file in network settings and re-did the tcp/ip stack and nothing seems to fix this issue. Certain links on web pages give me an error message that the server cannot connect to the specified server link. I am attaching a picture of this error message, but this is not the only time and place I sometimes get this. I get it using Firefox 29.0.1, Cyberfox latest version and IE 10 will also give an error if I do the same thing. My laptop does not have this issue and I am at a loss to try and determine what is wrong. Short of reinstalling Windows from a clean drive, any ideas what else I can try. Thanks
    • #1454907
      It would probably help if you put your clock right – it’s displaying 8/13/2013
      This is because Certificates are sync’d to your clock and if there’s a mismatch, you won’t connect.
      • #1454941
        That is when that screen capture was taken. The clock on my PC IS correct.
    • #1454955
      I can occasionally get a failed to connect and hitting Refresh usually does the job, but in some cases (using IE10), I go to Tools – Internet Options – Content and Clear the SSL state.
      I’ll also run MS’s fixit to reset the Hosts file http://support.microsoft.com/kb/972034
      Problems with IE can affect other browsers and resetting IE to defaults can often resolve.
      Bookmark this URL http://www.downforeveryoneorjustme.com/ and the next time it happens, check to see if it is the site or if it’s on your end.
    • #1455082
      Not sure exactly what did it, but issue seems to be fixed. No joy yesterday, but today all seems well. Thanks
    • #1455089
      Glad to hear it.
      If you can get to other websites then the problem would normally be with the one that you can’t, but if you are unable to get to any website, then try the browser without add-ons.
    Reply To: Some links in web pages will not load
