• Testing Backslash removal problem
    Home » Forums » Testing Forum » Testing Backslash removal problem
    Ok, Here’s some powershell code to see if the backslashes get removed when bracketed by pre tags:
      | Move files listed in a file using RoboCopy while        |
      | preserving the directory structure by appending the     |
      | source path (minus the drive spec) to the destination   |
      | path.                                                   |
    Clear-Host
    $source = Get-Content "G:\Test\111.txt" -Encoding UTF8
    $destination = "G:\BEKDocs\Test"
    Foreach ($SrcPath in $source) {
      $file     = Split-Path -Path $SrcPath -Leaf
      $path     = Split-Path -Path $SrcPath -parent
      $PLen     = $Path.Length -3
      $PAdd     = $Path.Substring(3,$PLen)
      $SavePath = Join-Path -Path $Destination -ChildPath $PAdd
      $robocopyOptions = @('/Move', '/copyall')
      $LogFile         =
            @('/log+:G:\BEKDocs\Transfer\log.txt')
      $CmdLine = @($path, $SavePath, $file) +
                   $robocopyOptions + $LogFile
      & 'robocopy.exe' $CmdLine
    } #End Foreach
    • #2472826
      Seemed to work OK.
    • #2472827
      Ok trying same code using the code tag button:
        | path.                                                   |
      Clear-Host
      $LogFile =
      } #End Foreach
      • #2472828
        Well, the code button didn’t work at all but the backslashes are there!
    • #2472829
      How about a simple path entered in Visual mode.
      C:\Windows\System32\Powershell
      • #2472830
        Well, it appears that I can’t make the error happen any more.
        • #2472849
          I think Susan added your IP address somewhere to make an exception for you so it wouldn’t strip the “\”. I don’t think Microfix and alejr did not have that exception for them, so they had a problem this morning. Susan may have fixed their IPs by now.
          The problem isn’t GONE, it’s just gone for those with the exception.
    Reply To: Testing Backslash removal problem
