• USB audio input device won’t start
    Home » Forums » AskWoody support » Windows » Windows 7 » Questions: Windows 7 » USB audio input device won’t start
    I am trying to get my tower computer running Windows 7 Home Premium, 64 bit to recognize a Radio Shack XLR to mini USB Microphone adapter. (This is a microphone preamp and analog-to-digital converter with USB digital audio output) This device was working but now it doesn’t and I can’t get it to work, I’ve tried it on several USB ports. When I connect the device to a different port, Windows indcates that it is installing the device but then the device doesn’t run. The device works fine on another computer (a netbook running Windows 7 Starter, 32-bit). I’m wondering whether there might be some conflict with the Realtek HD audio manager which also has (analog) microphone inputs, though I disbled those and the device still doesn’t run. How do I go about diagnosing and solving this problem? Here’s the error message in the Windows Action Center. Thanks for any help.
    Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 10.
    Problem signature
    Problem Event Name: PnPDeviceProblemCode
    Architecture: x64
    Hardware Id: USBVID_0001&PID_0100&REV_0100&MI_00
    Setup class GUID: {4d36e96c-e325-11ce-bfc1-08002be10318}
    PnP problem code: 0000000A
    Driver name: usbaudio.sys
    Driver version: 6.1.7601.17514
    Driver date: 11-21-2010
    OS Version: 6.1.7601.2.1.0.768.3
    Locale ID: 1033
    • #1405990
      Are you sure you have a 64-bit driver?
      • #1406041
        All the drivers are the ones Windows supplies automatically. No drivers were supplied with the device. I assume 64-bit but who knows.
    Reply To: USB audio input device won’t start
