• Using COUNTIF on cells with formulas
    I am trying to count the number of cells in a column that contain the number 1. However, the cells being counted are actually formulas and if you PasteValues on the column most of the cells displaying a 1 are actually less than 1 or greater than one but less than 2. I think the formula needs to take the actual values into consideration. Something like, countif(value(range,”>0″)+countif(value(range,”<2")))). I have something just not right because Excel doesn't like the formula. What am I not seeing?
    TIA
    Viewing 24 reply threads
    • #1199528
      TIA
    • #1199963
      TIA
    • #1200719
      TIA
    • #1201638
      TIA
    • #1202409
      TIA
    • #1203282
      TIA
    • #1204123
      TIA
    • #1198405
      How about this:
      =COUNTIF(range,”>0″)-COUNTIF(range,”>=2″)
      Steve
      • #1205285
        Steve, the formula works fine for counting all the 1s but now I need to count all the 2s, then the 3s, 4s, and 5s. I had to modify the formula because of rounding so the working formula is
        =COUNTIF(K5:K161,”>0″)-COUNTIF(K5.K161,”>1.4″)
        Do I need to use AND with the COUNTIF in order to just get the 2s?
        TIA
    • #1199535
      How about this:
      Steve
    • #1199967
      How about this:
      Steve
    • #1200723
      How about this:
      Steve
    • #1201642
      How about this:
      Steve
    • #1202413
      How about this:
      Steve
    • #1203289
      How about this:
      Steve
    • #1204127
      How about this:
      Steve
    • #1198412
      That did it. Thanks Steve.
    • #1199557
    • #1199974
    • #1200730
    • #1201649
    • #1202420
    • #1203301
    • #1204134
    • #1205310
      Making just a slight change to Steve’s formula…
      =COUNTIF(range,”>=2″)-COUNTIF(range,”>=3″)
      Should return the number of values that are greater than or equal to 2, while being less than 3. Is that what you needed?
    • #1205333
      If you want to count the rounded values, you could try:
      =SUMPRODUCT(–(ROUND(K5:K161,0)=2))
      • #1205471
        Rory and Ricky, both formulas work but the one using ROUND seems easier since I can just use whole numbers. Thank you both very much.
    Reply To: Using COUNTIF on cells with formulas
