• what if formula problem (excel 2000)
    • This topic has 6 replies, 3 voices, and was last updated 18 years ago.
    What is problem with this “IF” formula. What must I do to check a range for a name and then report the results of another cell?
    Thanks for the help
    • #1065068
      Personally I’d use the VLOOKUP function on this.
      =VLOOKUP(A5,A5:E8,5) entered in G5.
      • #1065233
        Thanks Preston,
        That is a better way to go.
        Appreciate the help
      • #1065430
        Hello Preston,
        I just gave this a try with the Vlookup after I said it seemed like a better way to go. I entered the formula in cell G5 as suggested and got the result from one cell below the desired. Where might this be in error?
        Thanks again for the assist
        • #1065437
          Preston accidentally forgot the last argument. it should be
          =VLOOKUP(A5,A5:E8,5,FALSE)
          FALSE means that you don’t want an approximate match, but an exact one.
    Reply To: what if formula problem (excel 2000)
